Google Docs can not work while Google Sheets and Calendar have no problem
I was trying to add a regular Google Docs node and it prevented me from accessing by showing “Unable to sign without access token”.
However, I followed the process to add OAuth 2.0 Client in Google Platform. How can I diagnose where is the issue?
While Google Calendar, Gmail, Google Sheets had no problem since they did not need id & secrets in adding the credentials. All the google api have been enabled in the Google Cloud Platform.
When clicking sign in with Google in adding credentials:
Access blocked: n8n.cloud has not completed the Google verification process
n8n.cloud has not completed the Google verification process. The app is currently being tested, and can only be accessed by developer-approved testers. If you think you should have access, contact the developer.
If you are a developer of n8n.cloud, see error details.
Error 403: access_denied
Details:
Node type:
`n8n-nodes-base.googleDocs`
Node version:
`2 (Latest)`
n8n version:
`1.84.1 (Cloud)`
Can you please go over this tutorial and see if you missed something?
Let me know how it goes!
If this solver your problem, please remember to mark my reply as the solution.
Thank you @solomon and the video is awesome. It turns out that I need to sign in the google once I fill the ID & secret, it should be a chain behavior. And also I forgot to add myself as test user. Really appreciate the info!
