Graphql POST not working, GET works
When I make a Graphql/HTTP POST request to the graphql endpoint for ShipHero, the API always returns a 500 error. The same method/body works in Postman with no issues.
I also pointed both requests to a requestbin, and couldn’t see any tangible difference
500 error from the endpoint
"message":
"Unexpected error. Please contact a system administrator."
  • n8n version: 1.17.1
  • n8n EXECUTIONS_PROCESS setting (default: own, main): own, main
  • Operating system: Ubuntu
Hey @JoeyP91,
Welcome to the community :raised_hands:
Does Shiphero provide any kind of logging that may help? Are you also doing the same auth request in Postman?
Hi @Jon
I am not sure RE shiphero logging - I could not find anything unfortunately.
Regarding auth, I actually use the token generated in the first step of my n8n workflow in Postman as well. So both requests use the same token.
Hey @JoeyP91,
Sadly that is all I have at the moment without seeing something that shows the post data from both attempts. It looks like something is returning the “please contact a system administrator” message so it would be handy to see where that is coming from.
Hi Jon,
I’ve managed to get it working by setting the Request Format to JSON on the GraphQL node. Thanks for your assistance and hope this helps someone else in the future.
This topic was automatically closed 7 hours after the last reply. New replies are no longer allowed.
