Hello, I want to use the Grist getAll node with some filters, and I’m not able to get them working. No matter what I try to input as a filter for my column title as a string, it does not find anything.
I can see that Grist seems to add square brackets, which is probably causing the problem, but I don’t know how to get rid of this. I also tried it as a formula, but it is the same outcome.
2025-10-27T12:33:22.413450214Z 2025-10-27 13:33:22.413 - info: ActiveDoc fetchQuery {"tableId":"YouTube","filters":{"Titel":["Beszel"]}} (regular) org=, email=info@xyz.com, userId=6, altSessionId=vfczF8b4TrW1FWxxGp1wBH, age=300, access=owners, docId=jS8itfr6dpm4eC7cueitDT
Empty
- n8n version: 1.116.2
- Database (default: SQLite): SQLite
- n8n EXECUTIONS_PROCESS setting (default: own, main): own (I think so)
- Operating system: Unraid / Linux
