Grist filter not working
I use the Grist integration and it works fine but the filter does not work because no matter what I insert, it will not find anything with the filter.
No error message but there are no entries.
This is the output without a filter value. As soon as I add false for this auto suggested column name it does output no entries. The same applies for every column. What is the reason?
  • n8n version: 1.72.1
  • Operating system: Linux / unRAID
Fun fact I found out now
This filter with Done, which is a boolean value with only true/false available works even without a value. If I don’t add any value and only the column name the ones with true are unselected and I only get the ones with false.
Hey @CptDayDreamer , it’s a boolean value but n8n thinks it is a string. To get it working, switch the value to expression mode to use {{ false }} instead.
