Guys facing the issue while account creation Help
Please check the checkbox.
This pop up comes out while creating the account. There is no option there to check the box.
Hi @Joee123
Try using a clean browser session without extensions. Sometimes ad blockers can interfere with certain website elements…
Hi @mohamed3nan, I have removed all extension, clear caches, but still I am facing the same issue, could you please check it on your end
Thanks
It’s working on my end.
Try using a new Incognito window, If it’s still not working, restart your router or try accessing it from another device.
Thanks, I am able to create account using my mobile phone
Thanks
