Hi. I’m setting up a basic workflow that includes a Webhook
trigger (POST endpoint), then extracting the body of the request for a subsequent community node to perform data validation with a JSON Schema. If the data validation node returns a validation error, the webhook should respond with a 400. Otherwise, it should respond with a 201 with a Respond to Webhook
node.
While the data validation node performs the validation correctly, I’m struggling to act upon that error. I’ve set the On Error -> Continue
option, but the downstream node seems not to pick the error properly (Haven’t managed to identify the error even trying with a Edit Fields
node to do a mapping). I’ve also set the On Error -> Continue (using error output)
but the error branch never gets to execute even if the node throws an error.
At this point I’m not exactly sure if the custom node is not throwing the error properly (according to the base code, it’s throwing a NodeApiError
with the validation errors) or it’s just me and my lack of knowledge of error handling in n8n. If it’s an issue with the custom node, I’d like to hear from you how to throw errors properly for this use case, so I can submit a PR. Otherwise, I’d appreciate a little help with the branching logic.
- n8n version: latest according to Docker Registry
- Database (default: SQLite): SQLite
- Operating system: MacOS 12.3.1
