Hey I am having trouble with hosting n8n on aws ec2. I have tried each and every best setting to make it work but it didn’t
- n8n version:
- Database (default: SQLite):
- Operating system:
hello @Arsh_Tyagi
The error says that you have very big pinned data. Why do you need to pin all 1799 items? And what is the reason for pinning the Code node right after another pinned node?
@barn4k I did run a test workflow and when you run it you can’t tell is the workflow is running or not and keeps on running forever
please fill in the template with the info of your installation.
