[Help/Advice] Building a fully autonomous AI Outreach & Reply Agent (Gmail + OpenAI + n8n)
Hi n8n Community,
I am building a sophisticated, end-to-end AI-driven outreach workflow and I’m looking for some architectural advice from those who have built similar “AI Agents.”
My Goal: I want to automate the entire sales development lifecycle within n8n, and if available without using 3rd party outreach platforms.
My Stack:
  • n8n (Cloud/Self-hosted)
  • OpenAI (GPT-4o) via the OpenAI Node
  • Gmail (For sending and receiving)
  • Apollo.io (As the lead source)
The Proposed Workflow & My Questions:
1. Enrichment & Research: I need to research each lead’s LinkedIn profile and company data before writing the email.
  • Question: Since direct scraping is risky, do you recommend using a specific API service (like ProxyCurl or Apollo) within n8n to fetch this data?
2. Hyper-Personalization: Using the research data, GPT should generate a unique email body for each person and company.
  • Question: How do you handle HTML formatting or line breaks within the Gmail node to ensure the AI-generated text looks natural and professional?
3. The “Reply Loop” & Threading (The Hard Part): This is where I need the most help. I want the workflow to:
  • Monitor Gmail for replies.
  • Identify the previous context of the conversation.
  • Generate an appropriate AI response.
  • Question: How do I efficiently manage Conversation Memory? Should I use the AI Agent node with Buffer Memory, or is it better to store threadId and history in a database (like Supabase) to feed it back into the prompt?
4. Error Handling & Rate Limits:
  • Question: What are the best practices for managing OpenAI API limits and Gmail sending limits when running several executions simultaneously?
I would love to hear from anyone who has implemented a persistent “memory” for email threads or anyone who has a template for an AI Sales Agent.
Thanks in advance for your insights!
Hi @Tmob
Hoper you’re doing well!
Great questions, what you’re building is a really common AI email agent pattern, and n8n supports this super well if the architecture is set up right. Looks like you’re already on the right track conceptually :+1:
About data collection (LinkedIn / companies):
Instead of scraping directly, the safest and most stable route is to use dedicated APIs like Apollo, ProxyCurl, or similar services. The recommended pattern in n8n is always API → structured JSON → AI, because it cuts down on failures, avoids legal issues, and makes it way easier for the model to work with. In your workflow, this just becomes an HTTP Request to the enrichment API, then passing the resulting JSON as context to OpenAI / AI Agent.
About email formatting in Gmail:
The simplest and most reliable approach is to have the model generate the final text with natural line breaks (\n\n) and send that directly through the Gmail node — this already produces pretty professional emails. If you want HTML, that works too as long as the model generates valid HTML, but for most cases well-formatted text is enough and way more robust.
About conversation memory:
This is where it’s important to separate use cases. For continuous chat within a single execution, the AI Agent with Window/Buffer Memory works well. But for email, that’s not enough because each new message coming in through the Gmail Trigger starts a new execution.
In these scenarios, the recommended practice is to store the history (or a summary of it) externally — for example in a database like Supabase — using the threadId as the key. Each time a new email comes in, you fetch that history, inject it into the prompt, and continue the conversation consistently. This is totally aligned with what n8n recommends for agents with long-term state.
About OpenAI and Gmail limits:
The main thing is to avoid too many parallel executions without control. n8n doesn’t do automatic rate limiting, so it’s worth using good workflow practices: retries with delays, wait nodes between sends, and error handling on OpenAI and Gmail nodes. At higher volumes, serializing sends or batching executions easily prevents limit issues.
So the architecture usually looks like this:
You enrich data via API, generate the email with AI, send it through Gmail. When a reply comes in, the Gmail Trigger fires, you fetch the history by threadId, pass the context to the AI and generate the response — saving that new turn in the database for the next interaction. It’s exactly the pattern n8n describes for more “real” and persistent agents.
Great project @Tmob! I’ve built similar systems. Here’s what works:
Conversation Memory (the hard part)
Architecture:
Gmail Trigger → Extract threadId → Fetch history (Supabase) → AI Agent → Send reply → Store turn
The key is injecting context into your prompt with the full conversation history keyed by threadId.
Rate Limits
  • Batch sends (30s delay)
  • Error Workflow for 429s → retry with backoff
  • Gmail: 100/day new accounts, 500 established
Enrichment
Apollo API works well. Also Clearbit + People Data Labs.
I built a free template for exactly this: AI Email Reply Agent - handles the conversation memory pattern.
Happy to help if you get stuck!
