Error when I use the NocoDB node to create a record.
Note: I’ve checked the API credentials, and it is okay, so I think there might be a bug in the NocoDB node.
For your info, I am using self-hosted NocoDB instance.
400 - {"msg":"Cannot destructure property 'options' of 'object null' as it is null."} - Cannot destructure property 'options' of 'object null' as it is null.
NodeApiError: Bad request - please check your parameters
at Object.execute (/usr/local/lib/node_modules/n8n/packages/nodes-base/dist/nodes/NocoDB/NocoDB.node.js:359:27)
at processTicksAndRejections (node:internal/process/task_queues:95:5)
at Workflow.runNode (/usr/local/lib/node_modules/n8n/packages/workflow/dist/Workflow.js:696:19)
at /usr/local/lib/node_modules/n8n/packages/core/dist/WorkflowExecute.js:656:53
- Same as error code
- n8n version: n8n ai beta version 1.19.0
- Database (default: SQLite): SQLite
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Operating system: Ubuntu 20.04
