You do not need to use the Move Binary Data node. You need a function node to map the base64 image to a binary structure in n8n and then reference the binary key in the Write Binary File node. Check the example below. Btw you might need to do a split in the incoming string to remove the data:image/jpeg,base64
Instead of sending the image to the webhook as base64, it should be much simple to send the image as binary when making the HTTP request to the Webhook. That way, n8n would do the transformation for you, meaning the Function node does have to be used.
"nodes": [
"parameters": {},
"name": "Start",
"typeVersion": 1,
"position": [
250,
300
"parameters": {
"values": {
"string": [
"name": "logo",
"value": "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"
"options": {}
"name": "Set",
"type": "n8n-nodes-base.set",
"typeVersion": 1,
"position": [
520,
300
"parameters": {
"functionCode": "return [\n {\n json: {},\n binary: {\n data: {\n\t\t\t\tdata: items[0].json.logo,\n\t\t\t\tmimeType: 'image/png', // Optional but should be set if possible (optional)\n\t\t\t\tfileExtension: 'png', // Optional but should be set if possible (optional)\n\t\t\t\tfileName: 'logo.png', // Optional but should be set if possible (optional)\n\t\t\t} }\n }\n]"
"name": "Function",
"typeVersion": 1,
"position": [
770,
300
"parameters": {
"fileName": "image.png"
"name": "Write Binary File",
"type": "n8n-nodes-base.writeBinaryFile",
"typeVersion": 1,
"position": [
990,
300
"connections": {
"Start": {
"main": [
"node": "Set",
"type": "main",
"index": 0
"Set": {
"main": [
"node": "Function",
"type": "main",
"index": 0
"Function": {
"main": [
"node": "Write Binary File",
"type": "main",
"index": 0
