Good afternoon, I would like to know if there is any way when receiving an event via webhook, it can only continue if the same workflow is not running at the time of receipt.
I’m talking about the aspect of workflow delaying the continuation, not delaying the response
It would be something similar to the photo, or using the IF node to check if the workflow is active, and if it is active it waits, instead of continuing
Or in the configuration of the webhook itself, it receives the data, but does not proceed further
My application in practice:
I use Google Sheets to make triggers on WhatsApp, where it reads the user’s data in the spreadsheet and then proceeds, doing them one by one, but the webhook happens to receive the trigger twice in a short period of time, which causes that the second workflow tries to send repeatedly to the user that the first workflow is already sending.
I tried to check Gogole Sheets at the beginning of the workflow, to check if a certain field has a value equal to or greater than 10, if so, the flow continues, if not, it should wait, in order to continue only if the first workflow had completed its 10 shots, however it happens to receive two messages in parallel in the webhook, and both end up interpreting that the value is greater than 10 and work in parallel. Is there any way to configure your own webhook or another node to check if there isn’t another similar workflow already working?
- **n8n version: ** Version 0.231.3
- **Running n8n via Docker
