Help me scrape Instagram
Hello, I would like to know how to scrape Instagram profiles based on very specific factors, such as location, age, gender, number of followers, etc..
(I need to use rapidAPI/Apify)?
Thank you for your response!!
Simplest and most cost-effective way of doing that is using the Apify Instagram Scraper.
You can call this directly with the Apify node in n8n, and then collect the results with the same.
