Hi all,
I’m building an AI agent (using n8n, OpenAI, Google Sheets, etc.) that takes workout logs sent from Telegram or WhatsApp and automatically adds the data to Google Sheets.
Currently, if I enter each workout movement one-by-one (e.g., as separate messages), it works fine and each movement goes into the correct row and columns.
The problem:
If I paste my whole workout (with multiple exercises and details—reps, weight, etc.) into the chat as a single message, the bot doesn’t split the exercises.
Instead, it either tries to put all of them into a single row/cell, only logs one exercise, or sometimes doesn’t log anything at all.
So, the AI agent isn’t separating or parsing each movement from a multi-line input.
Example input I want to send:
400m run
60x db deadlift 32 kg
400m run
60 x Dumbell snatch 15 kg
400m run
60 x db goblet squats 16 kg
400m run
60 x Dumbell oh press 12.5KG
Date | Movement | Reps | Weight |
03/06/2025 | Bench Press | 60 | 60kg |
Pull Ups | 60 | Bodyweight | |
Deadlift | 60 | 100kg |
