Help Needed: n8n is not saving workflows to Postgres on Render
Hi all, I’m trying to self-host n8n on Render.com, and I’ve set up a Postgres database, but workflows are still not saving to it. After every restart, everything is lost.
Here’s what I’ve done:
Configured render.yaml with these environment variables (scrubbed passwords):
I see that you mentioned you’re using the free instance of Render.
Render’s free instance always shuts down after 15 minutes of inactivity.
That’s why, when you restart the server, it starts fresh and doesn’t retain any saved workflows.
For this use case, I recommend using an external Postgres database instead of the one provided by Render itself.
Why?
Because in this case, even if your instance becomes inactive, when you restart the server, it will reconnect to the same external database with all your saved data.
How to do this?
The easiest and free way is by using Supabase. Create a database there and get the credentials.
Pro tip: Set the Supabase project’s region to the same region where you’ve deployed n8n on Render for better performance.
Next, just replace the Postgres database-related environment variables with the ones you get from Supabase.
That’s it…hope it helps!
Still, if you need any help or would like a detailed guide on setting up n8n on Render, let me know. I’ll write up a step-by-step document and share it here.
For anyone else who finds this post/thread re: render.com’s free/hobby tier services, also be aware that Render will expire the postgres instance after 30 days, and then hold your n8n instance data hostage, only allowing you to get the data back in exchange for an upgrade to a paid plan. You have to dig a bit (scroll down, expand the detailed info, and notice the subtle parenthetical note - screenshot below) to find the “30 day limit” on their pricing page. IMO, this database instance “expiration” is an even more compelling reason to configure n8n’s database somewhere NOT on Render if what you want is a free/experimental hosted instance. Given how buried this information is regarding the significant “gotcha” limitation on the “free” service, (i.e. drug-sample tactic), I would be reluctant to use Render at all.
