I need help to read a binary file data, and use the values inside a function node. so far I use the “Read Binary File” node, then “Move Binary to JSON”. so far I have the values. How can I reference them inside my function node? I know the following piece of code exists: const staticData = getWorkflowStaticData(‘node’); but I’m not a JS expert to know how to use it.
Please share the workflow
n8n version: 0.170
Database you’re using (default: SQLite): SQLite
- Running n8n with the execution process [own(default), main]:
Running n8n via [Docker, npm, n8n.cloud, desktop app]: Docker
Adding the output of the “Move Binary to Json” node
"at": "xxxxxxxxxxxxxxx",
"rt": "xxxxxxxxxxxxxxxxxx",
"user": {
"clientInfo": {
"model": "xxxxx",
"os": "xxxxx",
"imei": "xxxxxxxxxxxx",
"romVersion": "xxx",
"appVersion": "xxxxxxxxxxx"
"_id": "xxxxxxxxxxxxx",
"email": "xxxxxxxxxxxxx",
"password": "xxxxxxxxxxx",
"appId": "xxxxxxxxxxxx",
"apikey": "xxxxxxxxxxxx",
"createdAt": "xxxxxxxxxxxxxxxxxxx",
"__v": 0,
"lang": "en",
"online": false,
"onlineTime": "xxxxxxxxxxxxx",
"appInfos": [
"os": "xxxx",
"appVersion": "xxxxx"
"ip": "xxxxxxx",
"location": "",
"offlineTime": "xxxxxxxxxxx",
"userStatus": "2",
"countryCode": "xxx",
"currentFamilyId": "xxxxxxxx",
"bindInfos": {
"gaction": [
"xxxxxxx"
"extraPush": {
"push": {
"type": "xxx",
"info": {
"token": "xxxxxxxxxxxxxxx"
"language": "xx",
"extra": {
"ipCountry": "xx"
"region": "xx"
next the function node should execute the following code:
const ewelink = require('ewelink-api');
const newConnection = new ewelink({
at: "value from binary file",
region: "value from binary file"
const devices = await newConnection.getDevices();
return [
json: devices
Hey @ja3four,
Welcome to the community
You can use the following code snippet to refer the values:
for at: $json.at
for region: $json.region
I hope this helps
