Help! Prompting Fine-Tuned Vector AI Model
I’ve been troubleshooting N8N for hours now trying to get an http request to post a chat input to a fine-tuned Vector AI model I made, I keep getting errors like “Bad request - please check your parameters Invalid JSON payload received. Unknown name “”: Root element must be a message.”
Anyone go through this before?
Hey! That error usually points to an issue with how the JSON payload is structured for Vertex AI chat models. To help debug this quickly, could you share:
  1. What model are you using? (e.g. chat-bison, text-bison, or a fine-tuned variant?)
  2. What’s the exact JSON body you’re sending in the HTTP Request node?
  3. Are you using manual Bearer token auth or OAuth2 credentials in n8n?
With this, I can guide you to a working config. Looking forward to your reply!
Also try to give input in the format given below:
JSON File:
“instances”: [
“messages”: [
“author”: “user”,
“content”: {{$json[“chat_input”]}} // Replace with your chat input value
