Help regex function!
Hi! im goingt crazy with what i thought was going to be aeasy thing. I have a string like this:
<https://cdn.shopify.com/s/files/1/0454/8182/0319/files/19795198-1_1.jpg>; rel="canonical"
I just wante to extract the URL , so i want the output to be:
I have no idea about javascript, but ive researced for formula’s and it seems REGEX should do it, however i keep running into different errors and have no idea why … i attach a screenshot of the last error i got … is it because ITEM isn’t a string and the REGEX function only works on strings?
ERROR: Cannot convert undefined or null to object
##?SCREENSHOT
Please share the workflow
  • Database you’re using (default: SQLite):
  • Running n8n with the execution process [own(default), main]:
  • Running n8n via [Docker, npm, n8n.cloud, desktop app]:
Hi @oly-dev would this do the trick for you?
const url = items[0].json.url;
let start = url.indexOf("<");
let stop = url.indexOf(">");
let result = url.substring(start +1, stop);
return {"result": result}
continuing on answer by @dickhoning here an alternative with the Regex pattern.
let result = url.match(“^<([^>]*)”)[1];
return {“result”: result}
