Help Scout Trigger Node no longer working
Hi, My Help Scout trigger node stopped working. It looks like Help Scout deprecated their v1 version of webhooks - Webhooks | Help Scout Developers
v2 is asking for a Secret Key when creating the app and I’m not sure what to do.
Having a look at this.
It’s working fine for me. It looks like you are creating a webhook, but you need to create an app. Go to your profile → my apps. That if you want to use the Help Scout Trigger, else you can create the webhook from Helpscout (As shown in the picture). You just need to add a webhook node to your workflow, grab the URL and paste it in the Callback URL parameter. The secret key is probably optional.
https://developer.helpscout.com/mailbox-api/overview/authentication/
