Help w/ badge pls :)
Hello! Like some others, I’m having issues with the badge etc. I’ve searched other threads to try and resolve.
  • Original quiz completion was 62% theory 100% workflow, and this is what shows in the verification link ( n8n Level 1 Course Verification )
  • I have taken the quiz multiple times with the theory up to 85% (per attached) but I still see the original results at that link
It’s been about 12 hours and nothing has updated. Could use a hand!
Hi @mackdz Welcome!
Can you share your unique_id please?
And if that says 62% on the verification link, then i believe you should retake that test, and then let me know if you pass that on verification link and still didnt received the badge.
Thanks for helping. I have taken the quiz 5 or 6 times now, several with theory sections above 80%, all with workflow 100%
498afe7879f3770025c4a5c49fa3399c
It looks like the verification is still only showing my first (lowest) score.
@mackdz i think you are correct, your score is stuck at 62%, i think we need @jamiemadden_n8n for this, as you have tried retaking the quiz and still your unique_id attched score stays the same & you have not received the badge.
Thanks, support on this would be very appreciated
Hi @mackdz
Your score has been sync’d and badge assigned. Nice work!
cheers,
Jamie.
Thanks all!
Helpful thread for anyone getting started with this. The step by step explanation and the follow up answers cover most of the common questions I had.
