Help with Google Sheets Append Issue in Workflow
I’m facing an issue where my n8n workflow processes 10 MCQs but only appends 1 row to Google Sheets.
Hello n8n Community,
I’m building a workflow to parse multiple-choice questions (MCQs) from a Google Doc, process them with OpenAI, and append the results to a Google Sheets document. The workflow successfully parses 10 MCQs (verified in the execution output), but only 1 row is added to the sheet despite the Google Sheets node receiving all 10 items.
Workflow Details:
  • Nodes Used: Google Docs (Get), Code (Parse MCQs), Split In Batches, OpenAI (Generate Answers), Set, Merge, Google Sheets (Append).
  • Issue: The Google Sheets node’s output shows 10 items processed, but the sheet only reflects 1 new row.
  • Input to Google Sheets: Each item contains fields like quizNo, subject, question, optionA, optionB, optionC, optionD, correctAnswer, etc.
  • Config: Append operation, manual column mapping, “Use Append Endpoint” enabled.
Troubleshooting Tried:
  • Verified input data structure (10 separate JSON objects).
  • Checked column mappings (match sheet headers).
  • Ensured Google credentials have full Sheets access.
  • Tested with a new blank sheet (same result).
Possible Causes Considered:
  • Nested data structure causing single-row write.
  • Mapping or API endpoint misconfiguration.
  • Overwriting in loop despite Merge node.
I’d appreciate any insights or suggestions to fix this. Could it be a batching issue or a need to adjust the Google Sheets node settings? Screenshots or workflow JSON can be shared if needed. Thanks for your help!
Hi @Pawan_Kumar
Could you share your workflow to make analysis?
It will be helpful in further analysis.
hi @Piotr_Sikora
in this workflow, if agent create 10 MCQs in one go, only 1 row added n only 1 MCQ uploads on the google sheet
