Help with google sheets read node
Hi all, I am struggling with one part of my personal finance workflow where I want n8n to read a large table from Google Sheets and then feed all of it to an OpenAI node. I already set it up but can’t figure out how to feed the OpenAI node the whole output from the Google Sheets read node. The table in GS is structured in 3 columns (Vendor, Category, Sub Category) and has about 400 rows. Each row is a Vendor that I have previously purchased from, and I categorized each vendor in the past under a category and sub category (e.g., Amazon, Entertainment, Online Shopping). I would like the OpenAI node to check this “database” of previously categorized vendors against the current one; if the vendor exists in the google sheets then use the same categories, if not then come up with appropriate ones. I just can’t seem to figure out how to feed the whole table in JSON format to the OpenAI node. Thanks for the help!
hello @PinkFloyd
you can use the Aggregate node to combine all input from the GS into one item
Thanks @barn4k . Tried using the Aggregate node, this is what I got back from the OpenAI node: (for debugging, I asked it if it could read the existing mapping data I provided)
“No, I cannot read the existing mapping as it appears to be formatted incorrectly. What I see is a repetitive series of “[object Object]”. This suggests that the data may be represented in a JavaScript object format, but it is not being displayed properly, making it impossible to extract any specific details about the vendors, their short names, categories, or subcategories. To provide a readable format, the data needs to be presented in a clear tabular structure or as a list.”,
All good, this resolved it. “toJsonString()”
{{ $json.data.toJsonString() }}
