Hi everyone ![]()
I’m working on a workflow to publish posts with images on LinkedIn using the ugcPosts endpoint, based on dynamic content from Google Sheets and Google Drive.
Linkedin Workflow - rev 2
Here’s what I have working so far:
- I successfully upload the image via
assets?action=registerUpload - I get the
urn:li:digitalmediaAsset:... - I collect the user’s
subvia the/userinfoendpoint - The body is sent as raw JSON under Content-Type
application/json
However, even though the request executes without errors (HTTP 200), the post is either:
- Problem with parameters
- Not appearing on my LinkedIn feed
Only text is working… .
Here’s the JSON body I’m using (dynamic version):
json
CopiarEditar
"author": "urn:li:person:{{$node['HTTP Request UserInfo'].json.sub}}",
"lifecycleState": "PUBLISHED",
"specificContent": {
"com.linkedin.ugc.ShareContent": {
"shareCommentary": {
"text": "{{$node['Pick One'].json.text}} • {{$now}}"
"shareMediaCategory": "IMAGE",
"media": [
"status": "READY",
"media": "{{$node['HTTP Request-RegisterUpload'].json.value.asset}}"
"visibility": {
"com.linkedin.ugc.MemberNetworkVisibility": "PUBLIC"
What I’ve already tried:
- Adding timestamps or random strings to the
textto avoid duplicates - Manually changing the asset ID and text
- Posting static versions (which work but don’t always show up on the feed)
Has anyone managed to make this work reliably with dynamic posts (text + image)?
Is there something I’m missing in the ugcPosts structure?
Thanks in advance for any help or insight!
— Pedro
