I am looking to loop through each day one by one, but it outputs everything entirely. How would I fix this problem?
- n8n version:
- Database (default: SQLite):
- Operating system:
Just found the split node! It solves it!
remember to mark the post as solved, you can mark your own comment
Also! Sorry for double comment
You don’t need the loop over node. Nodes run once for each item by default. The Loop over items node is rarely actually needed
Thank you for that! You just saved me a lot of headaches. Is there a way to reference the last item in an array?
I want to have an IF node that always checks the last item of an array: {{ $json.availableTimeSlotList }}
I want to always check for the last “startTime” of a given day, and compare it with a value. Would I need a loop for that? @liam
“date”: “2024-04-09”,
“dayOfWeek”: “Tuesday”,
“isOpen”: true,
“availableTimeSlotList”: [
“startTime”: “2024-04-09T08:00:00”,
“endTime”: “2024-04-09T10:00:00”,
“dropOffTime”: “2024-04-09T07:45:00”,
“pickUpTime”: “”,
“bayGuid”: “d66028dd-453a-ed11-8103-0050569839a7”
“startTime”: “2024-04-09T09:00:00”,
“endTime”: “2024-04-09T11:00:00”,
“dropOffTime”: “2024-04-09T08:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-09T10:00:00”,
“endTime”: “2024-04-09T12:00:00”,
“dropOffTime”: “2024-04-09T09:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-09T13:00:00”,
“endTime”: “2024-04-09T15:00:00”,
“dropOffTime”: “2024-04-09T12:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-09T14:00:00”,
“endTime”: “2024-04-09T16:00:00”,
“dropOffTime”: “2024-04-09T13:45:00”,
“pickUpTime”: “”,
“date”: “2024-04-10”,
“dayOfWeek”: “Wednesday”,
“isOpen”: true,
“startTime”: “2024-04-10T16:00:00”,
“endTime”: “2024-04-10T18:00:00”,
“dropOffTime”: “2024-04-10T15:45:00”,
“pickUpTime”: “”,
“bayGuid”: “d76028dd-453a-ed11-8103-0050569839a7”
“startTime”: “2024-04-10T17:00:00”,
“endTime”: “2024-04-10T19:00:00”,
“dropOffTime”: “2024-04-10T16:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-10T18:00:00”,
“endTime”: “2024-04-10T20:00:00”,
“dropOffTime”: “2024-04-10T17:45:00”,
“pickUpTime”: “”,
“date”: “2024-04-16”,
“isOpen”: true,
“startTime”: “2024-04-16T08:00:00”,
“endTime”: “2024-04-16T10:00:00”,
“dropOffTime”: “2024-04-16T07:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-16T09:00:00”,
“endTime”: “2024-04-16T11:00:00”,
“dropOffTime”: “2024-04-16T08:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-16T10:00:00”,
“endTime”: “2024-04-16T12:00:00”,
“dropOffTime”: “2024-04-16T09:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-16T13:00:00”,
“endTime”: “2024-04-16T15:00:00”,
“dropOffTime”: “2024-04-16T12:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-16T14:00:00”,
“endTime”: “2024-04-16T16:00:00”,
“dropOffTime”: “2024-04-16T13:45:00”,
“pickUpTime”: “”,
“date”: “2024-04-17”,
“isOpen”: true,
“startTime”: “2024-04-17T08:00:00”,
“endTime”: “2024-04-17T10:00:00”,
“dropOffTime”: “2024-04-17T07:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-17T09:00:00”,
“endTime”: “2024-04-17T11:00:00”,
“dropOffTime”: “2024-04-17T08:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-17T10:00:00”,
“endTime”: “2024-04-17T12:00:00”,
“dropOffTime”: “2024-04-17T09:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-17T13:00:00”,
“endTime”: “2024-04-17T15:00:00”,
“dropOffTime”: “2024-04-17T12:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-17T14:00:00”,
“endTime”: “2024-04-17T16:00:00”,
“dropOffTime”: “2024-04-17T13:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-17T15:00:00”,
“endTime”: “2024-04-17T17:00:00”,
“dropOffTime”: “2024-04-17T14:45:00”,
“pickUpTime”: “”,
“bayGuid”: “d86028dd-453a-ed11-8103-0050569839a7”
“startTime”: “2024-04-17T16:00:00”,
“endTime”: “2024-04-17T18:00:00”,
“dropOffTime”: “2024-04-17T15:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-17T17:00:00”,
“endTime”: “2024-04-17T19:00:00”,
“dropOffTime”: “2024-04-17T16:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-17T18:00:00”,
“endTime”: “2024-04-17T20:00:00”,
“dropOffTime”: “2024-04-17T17:45:00”,
“pickUpTime”: “”,
“date”: “2024-04-18”,
“dayOfWeek”: “Thursday”,
“isOpen”: true,
“startTime”: “2024-04-18T08:00:00”,
“endTime”: “2024-04-18T10:00:00”,
“dropOffTime”: “2024-04-18T07:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-18T09:00:00”,
“endTime”: “2024-04-18T11:00:00”,
“dropOffTime”: “2024-04-18T08:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-18T10:00:00”,
“endTime”: “2024-04-18T12:00:00”,
“dropOffTime”: “2024-04-18T09:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-18T13:00:00”,
“endTime”: “2024-04-18T15:00:00”,
“dropOffTime”: “2024-04-18T12:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-18T14:00:00”,
“endTime”: “2024-04-18T16:00:00”,
“dropOffTime”: “2024-04-18T13:45:00”,
“pickUpTime”: “”,
“date”: “2024-04-19”,
“dayOfWeek”: “Friday”,
“isOpen”: true,
“startTime”: “2024-04-19T16:00:00”,
“endTime”: “2024-04-19T18:00:00”,
“dropOffTime”: “2024-04-19T15:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-19T17:00:00”,
“endTime”: “2024-04-19T19:00:00”,
“dropOffTime”: “2024-04-19T16:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-19T18:00:00”,
“endTime”: “2024-04-19T20:00:00”,
“dropOffTime”: “2024-04-19T17:45:00”,
“pickUpTime”: “”,
“date”: “2024-04-20”,
“dayOfWeek”: “Saturday”,
“isOpen”: true,
“startTime”: “2024-04-20T08:00:00”,
“endTime”: “2024-04-20T10:00:00”,
“dropOffTime”: “2024-04-20T07:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-20T09:00:00”,
“endTime”: “2024-04-20T11:00:00”,
“dropOffTime”: “2024-04-20T08:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-20T10:00:00”,
“endTime”: “2024-04-20T12:00:00”,
“dropOffTime”: “2024-04-20T09:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-20T13:00:00”,
“endTime”: “2024-04-20T15:00:00”,
“dropOffTime”: “2024-04-20T12:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-20T14:00:00”,
“endTime”: “2024-04-20T16:00:00”,
“dropOffTime”: “2024-04-20T13:45:00”,
“pickUpTime”: “”,
“date”: “2024-04-21”,
“dayOfWeek”: “Sunday”,
“isOpen”: true,
“startTime”: “2024-04-21T09:00:00”,
“endTime”: “2024-04-21T11:00:00”,
“dropOffTime”: “2024-04-21T08:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-21T10:00:00”,
“endTime”: “2024-04-21T12:00:00”,
“dropOffTime”: “2024-04-21T09:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-21T13:00:00”,
“endTime”: “2024-04-21T15:00:00”,
“dropOffTime”: “2024-04-21T12:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-21T14:00:00”,
“endTime”: “2024-04-21T16:00:00”,
“dropOffTime”: “2024-04-21T13:45:00”,
“pickUpTime”: “”,
“date”: “2024-04-22”,
“dayOfWeek”: “Monday”,
“isOpen”: true,
“startTime”: “2024-04-22T08:00:00”,
“endTime”: “2024-04-22T10:00:00”,
“dropOffTime”: “2024-04-22T07:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-22T09:00:00”,
“endTime”: “2024-04-22T11:00:00”,
“dropOffTime”: “2024-04-22T08:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-22T10:00:00”,
“endTime”: “2024-04-22T12:00:00”,
“dropOffTime”: “2024-04-22T09:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-22T13:00:00”,
“endTime”: “2024-04-22T15:00:00”,
“dropOffTime”: “2024-04-22T12:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-22T14:00:00”,
“endTime”: “2024-04-22T16:00:00”,
“dropOffTime”: “2024-04-22T13:45:00”,
“pickUpTime”: “”,
“date”: “2024-04-23”,
“isOpen”: true,
“startTime”: “2024-04-23T08:00:00”,
“endTime”: “2024-04-23T10:00:00”,
“dropOffTime”: “2024-04-23T07:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-23T09:00:00”,
“endTime”: “2024-04-23T11:00:00”,
“dropOffTime”: “2024-04-23T08:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-23T10:00:00”,
“endTime”: “2024-04-23T12:00:00”,
“dropOffTime”: “2024-04-23T09:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-23T13:00:00”,
“endTime”: “2024-04-23T15:00:00”,
“dropOffTime”: “2024-04-23T12:45:00”,
“pickUpTime”: “”,
“startTime”: “2024-04-23T14:00:00”,
“endTime”: “2024-04-23T16:00:00”,
“dropOffTime”: “2024-04-23T13:45:00”,
“pickUpTime”: “”,
I added a loop node after the switch node to loop through each day, now I just need a way to check for the last item in the array. When I copy the item path I get - {{ $json[“availableTimeSlotList”][“4”][“startTime”] }}
The problem is that it won’t always be index “4” everytime.
Is there a way to change it to something like {{ $json[“availableTimeSlotList”][“last-item”][“startTime”] }}
Very easy!
try this {{ $json[“availableTimeSlotList”].last()[“startTime”] }}
.last() is an array methof to get the last item.
If you want to share your workflow i can look over the whole thing
just highlight the entire workflow and copy and paste the code as shown below with the tick marks `
paste your workflow code here
I’m having trouble getting the last item still, I pasted the workflow below. Thanks for your help Liam
UXcfV2vAao2KE9Nm
I don’t think I did that right, where do I get the workflow code?
Wow! I had no idea you could do that. Thank you so much! I actually ended up solving the issue, that you so much for your help @Liam .
Random question, what video editing software did you use for that video? I loved how it zoomed in and out, super cool.
It’s called screen studio
