Help with Nested Json Format
I was working with a workflow to send data from QuestDB to an endpoint and the endpoint requires a certain format which is for eg:
Output
"Inputs": {
  "myArray": [
      "version": 5,
      "permissionMask": 1
      "version": 126,
      "permissionMask": 1
But after doing all merge and Item split node with operation as Aggregate items, I get data as follows:
Output
  "myArray": [
      "version": 5,
      "permissionMask": 1
      "version": 126,
      "permissionMask": 1
Could you give a suggestion what should be done to get the former format which is acceptable by the endpoint.
Hi @Meghna_jose
You could use the set node with a field “Inputs” and value of your second output. That would nest it back into “Inputs”.
Hi @BramKn ,
Thanks for your response, I had tried that earlier, but that just replaces the previous field name.
Ah yes of course.
try this in second set:
$json
so without the fieldname of the first Set.
Thanks a lot @BramKn , it works.
