Hi,
I need some help with regex on a set node.
As I understand it’s possible but I can’t get it to work ![]()
I would like to remove the
and
from the beginning and end of the sentence.Thanks ![]()
Hi,
and
Hi @Cizco,
To remove the html tags in the Set node you don’t need to use a regex expression. Simply use the split statement to remove them from the string.
{{$json["properties"].split("<p>")[1].split("</p>")[0]}}
Hi @martinhache,
Thank you!
That worked great ![]()
