I am utilizing a self hosted n8n instance (in docker). I am accessing my n8n instance via Cloudflare Tunnel, with a published application route directing to the n8n.vtinc.com.br subdomain.
No specific path was specified.
After multiple hours of trying, I could not make the webhook (nor the telegram trigger) to function (at all).
Actions (sending messages, editing messages, deleting messages) works as expected.
Non-Functional Webhook Integration, with Telegram Trigger. Observed with the Webhook Trigger, but inconsistent.
The Webhook returns a 403 Error or “provided secret is invalid”
Command (n8n provided for Telegram):
curl -X POST “https://n8n.vtinc.com.br/webhook-test/—————–/webhook”
{“message”:“Provided secret is not valid”}
Share the output returned by the webhook?
“ok”: true,
“result”: {
“url”: “https://n8n.vtinc.com.br/webhook/---------4e87-45b1-9f93-b025--------”,
“has_custom_certificate”: false,
“pending_update_count”: 5,
“last_error_date”: 1760138512,
“last_error_message”: “Wrong response from the webhook: 403 Forbidden”,
“max_connections”: 40,
“ip_address”: “—.—.–.-”
(Telegram API Information; n8n does NOT return any errors, since the webhook is never triggered)
Docker Compose Config:
services:
n8n:
image: docker.n8n.io/n8nio/n8n
container_name: n8n
ports:
- "5678:5678"
environment:
GENERIC_TIMEZONE: "America/Sao_Paulo"
TZ: "America/Sao_Paulo"
N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS: "true"
N8N_RUNNERS_ENABLED: "true"
N8N_SECURE_COOKIE: "false"
N8N_HOST: "n8n.vtinc.com.br"
WEBHOOK_URL: "https://n8n.vtinc.com.br"
N8N_USE_PROXY: "true"
N8N_TRUSTED_PROXIES: "loopback,linklocal,uniquelocal"
N8N_DIAGNOSTICS_ENABLED: "false"
volumes:
- n8n_data:/home/node/.n8n
- /var/run/docker.sock:/var/run/docker.sock
restart: unless-stopped
tty: true
stdin_open: true
volumes:
n8n_data:
Debug Info
[details="instance information"]
# Debug info
## core
- n8nVersion: 1.114.4
- platform: docker (self-hosted)
- nodeJsVersion: 22.19.0
- nodeEnv: production
- database: sqlite
- executionMode: regular
- concurrency: -1
- license: enterprise (production)
- consumerId: 294b5f9d-7151-----------0617950c518d
## storage
- success: all
- error: all
- progress: false
- manual: true
- binaryMode: memory
## pruning
- enabled: true
- maxAge: 336 hours
- maxCount: 10000 executions
## client
- userAgent: mozilla/5.0 (windows nt 10.0; win64; x64) applewebkit/535.0 (khtml, like gecko) chrome/139.0.0.0 safari/535.0
- isTouchDevice: false
## security
- secureCookie: false
Generated at: 2025-10-10T23:31:29.223Z
[/details]
P.S I know that the secure cookie setting is not exactly secure, but I kinda need the http settings.
PS2: Is my configuration adequate and complete?
- n8n version: 1.114.4
- Database (default: SQLite): SQLite
- n8n EXECUTIONS_PROCESS setting (default: own, main): Default
- Running n8n via Docker Compose
- Operating system: Debian 13
