Heroku deployment with n8nio/n8n:ai-beta fails with PG SSL issue
Forked the repo, replaced the normal docker image with the ai beta image and tried deploying on heroku. Everything else, including the env vars, are unchanged. Get this error:
2023-11-30T10:17:49.116207+00:00 app[web.1]:
2023-11-30T10:17:50.978629+00:00 app[web.1]: Initializing n8n process
2023-11-30T10:17:51.209885+00:00 app[web.1]: Error: There was an error initializing DB
2023-11-30T10:17:51.210157+00:00 app[web.1]: DatabaseError: no pg_hba.conf entry for host "54.155.157.92", user REDACTED, database REDACTED, no encryption
2023-11-30T10:17:53.306402+00:00 heroku[web.1]: Process exited with status 1
2023-11-30T10:17:53.327263+00:00 heroku[web.1]: State changed from starting to crashed
Has anyone successfully deployed the ai beta image to heroku?
Thanks!
Hey @Marcelo_Emmerich,
Welcome to the community :cake:
Is there more to the error or is that it? It could be that you need to set DB_POSTGRESDB_SSL_REJECT_UNAUTHORIZED to false in your env options.
OMG that worked! Thanks a lot!
