The ID’s are not recognizing the custom field names and I am not able to drag and drop the values into property values in SET node.
High Level just rolled out an update that likely changed data structure with Contact field folders for organizing in the UI. I suspect this is part of the problem.
Hi @davidl, I am sorry to hear you’re having trouble. It seems highlevel doesn’t accept my credit card so I couldn’t test anything myself there
Any chance you can share some additional details? What exactly are you trying to do with the node and which error are you seeing? Are you using the latest version of n8n?
