[Hiring] n8n Automation Specialist — Paid, Long-Term, Remote (E-Commerce / Shopify)
Hey everyone,
We run a e-commerce brand with 10+ social media accounts. We need an n8n developer to build us an AI-powered video generation pipeline from scratch.
What we need built:
  • An n8n workflow that takes competitor scripts/prompts → generates short-form video content using AI video tools → transcribes videos into 8sec increments → outputs ready-to-post videos with our own avatars
  • Integration with Google Drive, Claude API for scripts, and AI video generation (Veo / Google Labs / similar)
Looking for:
  • Experience building content production n8n workflows
  • Comfortable with AI APIs, video generation tools, and JavaScript Code nodes
  • Can figure things out independently — we’ll give you the vision, you build it
Paid, long-term, fully remote. DM me or reply here if this is your thing.
Hey @Nikolaos_Zissidis ,
This is exactly the kind of system I’ve been building with n8n.
I’ve already worked on AI content pipelines where we go from script generation → video creation → processing → ready-to-post outputs, so your use case (competitor scripts → AI videos → segmented clips → avatars) is very doable.
I’m comfortable with:
– Claude API for script generation
– AI video tools (Veo / similar alternatives)
– Custom logic inside n8n (Code nodes, API handling, scaling workflows)
– End-to-end automation with storage like Google Drive
More importantly, I don’t just “connect nodes” — I design systems that actually run reliably at scale across multiple accounts.
Happy to discuss your exact setup and map this properly before building.
You can check some of my work here:
https://muhammad-ai-automations.notion.site/Muhammad-Bin-Zohaib-AI-Automation-Projects-29da292a241380f889c2e337a134c010
Feel free to DM me or we can jump on a quick call and go deeper.
Hey Nikolaos, welcome to the community :waving_hand:
You’re definitely in the right place for this. n8n is perfect for building pipelines like the one you’re describing.
Your workflow idea makes a lot of sense: taking competitor prompts → generating scripts with Claude → creating short-form videos with AI tools → segmenting them into 8-second clips → then automatically organizing the ready-to-post content in Google Drive. That type of multi-step automation is exactly what n8n handles really well.
I’ve been working with n8n automation involving AI APIs, custom code nodes, and content pipelines, so I’d be happy to help design and build this end-to-end.
If you’d like, we can quickly go through the architecture and tools you’re planning to use.
You can reach me here or by email: [email protected]
[email protected]
Or grab a time that works for you here my calendar.
Looking forward to hearing more about the project.
Best,
Folafoluwa Stephen
Hey, this is literally what i do day to day.
I’ve got a full AI video pipeline running in n8n right now for DTC clients, Claude for script, images get generated per scene, then Kling 3 or Seedance 2 turns them into video clips, ElevenLabs does voiceover, FFmpeg composites everything with subtitles. Whole thing runs end to end with approval checkpoints built in.
I’m deep in Claude API, Google Drive integrations, JS Code nodes, and video gen APIs - i even built a custom API wrapper for Seedance 2 (i believe noone else has it as of today). Been doing video production for 12+ years (4,000+ projects on Fiverr) so i know the content side too, not just the automation.
Happy to jump on a quick call and walk you through the existing pipeline if you want to see how it works. DM me and i can send a Loom too.
You can contactl me at [email protected]
I can build a fully automated n8n pipeline that turns competitor inputs into AI-generated short-form videos with avatars, ready for posting across your social channels. This will streamline your content production, reduce manual work, and enable consistent high-volume output at scale.
Here’s the approach:
• Capture scripts/prompts → process via Claude API
• Generate videos using AI tools (Veo/Labs)
• Segment + transcribe into 8-sec chunks
• Apply avatars + branding overlays
• Store/export via Google Drive + ready-to-post format
Let’s schedule a call to discuss the details further.
Hey Nikolaos,
I saw your post and this is exactly the kind of project I work on. I build AI automation workflows in n8n pipelines that connect LLMs, video/media APIs, Google Drive, and external webhooks end to end.
For your use case (competitor script → AI video → avatar output → ready-to-post), I’d structure it as a modular n8n pipeline with Claude API for script generation, a video gen API (Veo/Runway/similar) triggered via HTTP nodes, and automated Google Drive output with metadata tagging per account. JavaScript Code nodes for any custom transforms in between.
I work independently and am comfortable figuring things out from a vision no hand-holding needed.
Can we jump on a quick call this week to go over the details?
— Nemanja
Hi Nikolas.
I have read your description and make a basic workflow in n8n.
I have experience on bulding AI-powered generation pipeline.
I’d like to work with you.
Hi, this is exactly the kind of workflow I specialize in.
I have 3+ years of experience building advanced n8n automation systems, including AI-driven content workflows, API integrations, and custom logic using code nodes. I’ve worked on systems involving content generation, data processing, and multi-step automation pipelines.
I’m comfortable integrating AI tools like Claude for script generation, handling media workflows, and building scalable pipelines that can generate and process content automatically.
I’m also a top supporter of the n8n community and focus on building clean, modular, and production-ready systems.
Would be great to connect and discuss your pipeline in more detail and schedule a short meeting.
I run Evara AI, incubated at IIT Bhubaneswar, and building multi-step content pipelines in n8n with Claude API integration is core to what I do. I have built production n8n workflows that chain LLM calls for script analysis, structured extraction, and content transformation – including timed segmentation logic similar to what you are describing with the 8-second transcription increments. On the integration side, I work regularly with Google Drive API, webhook triggers, and custom HTTP nodes to tie external tools into n8n sequences with error handling and retry logic baked in. I have a few slots open this week and could prototype the competitor-script-to-video pipeline quickly. DM me or reach out at [email protected] if you want to discuss the architecture.
Muhammad_Bin_Zohaib I’m building a free directory for n8n automation specialists
so SMBs can find and hire them directly — no platform fees. I’d love to give you a free featured listing during our beta.
Would you be open to a quick chat or just filling out a short profile form?
Hi Nikolaos_Zissidis,
This is definitely something we can help with.
At Hashlogics, we build custom AI workflows and automation systems, including n8n setups that connect content inputs, LLMs, media generation tools, storage, and post-processing into one smooth pipeline. Your use case around competitor-driven script flow, AI video generation, transcription in timed chunks, and ready-to-post branded outputs with avatars is very much in line with the kind of systems we build.
We are comfortable with n8n, Claude API, Google Drive integrations, JavaScript code nodes and stitching together AI tools into a reliable production workflow. We can take your vision and turn it into a practical, scalable system that your team can actually run day to day.
Website: HashLogics.com/
Book a call: Calendly Link
Hi!
I’ve built exactly this kind of “Content Factory” before. Automating short-form video isn’t just about connecting APIs; it’s about managing the logic of scripts, timestamps, and multi-modal AI (Video + Voice + Captions) without losing quality.
How I will build your video pipeline in n8n:
  • Script Intelligence: I’ll use Claude 3.5 Sonnet to analyze competitor hooks and rewrite them into high-converting scripts tailored to your brand voice.
  • Video Generation Orchestration: I’ll integrate with Veo (Google), Kling, or HeyGen/ElevenLabs (depending on your preference for avatars) via API, handling everything from prompt engineering to raw file management.
  • Precision Editing via JS: I’ll use JavaScript Code nodes in n8n to handle the logic of splitting videos into 8-second increments and aligning them with transcriptions for perfect pacing.
  • Cloud Infrastructure: I’ll set up the entire flow to pull from/save to Google Drive, ensuring your social media team has a ready-to-post library without manual uploads.
Why I’m the right fit:
  • Proven Video AI Experience: I have hands-on experience building automated content systems using Kling AI, ElevenLabs, and n8n.
  • Technical Ownership: I don’t need a step-by-step guide. I’ll handle the Docker/VPS environment, API rate limits, and error handling so the pipeline runs 24/7.
  • Live Proof: My own infrastructure is fully automated, from my portfolio site to my lead management. You can see my engineering style here: https://mikedevai.netlify.app/
Let’s connect and get this factory running:
I’m ready to jump on a call, show you how I’ve handled video automation in the past, and start building your MVP this week.
Sure, Let’s discuss.
Hi @Nikolaos_Zissidis
You can actually get started with this without needing a specialist.
This template is designed to be plug-and-play and covers the full pipeline end-to-end, so you can follow it step by step and adapt it to your needs:
https://n8n.io/workflows/3442-fully-automated-ai-video-generation-and-multi-platform-publishing/
In my experience, it’s a solid starting point to validate the use case quickly, and you can always iterate or customize it later as your requirements grow.
check emails!
I reached out to you via email, please share some of your work :+1:
Thats heat! Sent you an e-mail :inbox_tray:
Please share your email or instagram tag so i can contact you! No hand-holding needed is exactly what we are looking for:))
Please share any contact information!
Please share any contact information (email or instagram)
