How can i fix this? (basic user) problem in node 'Append row in Sheet'
Hello :slight_smile:
i’m learning n8n
i got a problem and it says 'Problem node ‘Append row in sheet’ Column names were updated after the node’s setup
where can i find this? and how to fix it?
hi @ENCO_GROUP ,
welcome to the community. can you please provide a photo of the sheet columns and a photo of the nodes parameters, would be helpful if you can click the dropdwon menu. Its possible that the columns were adjusted right after setting the node and the node is having a problem mapping to it
