how can i insert content in google word in place of variable
pleas Help Me i wanted to create payment receipt using word
HI @Gaurav_Garg
Can you share your current workflow and mention any errors or where you’re getting stuck so we can understand a little bit better what you’re trying to do? That would help us out - you can select all of your nodes bit hitting cmd/ctrl + a and then cmd/ctrl + c, which you can then paste between two sets of three backticks (```) here on the forums.
Filling this out would also help us:
i wanted to make invoice using googel doc how can i do that @EmeraldHerald @jan
Hi @Gaurav_Garg
You really don’t need to ping myself or Jan - if you reply, we’ll see it. ![]()
I made a very quick example showing you how you can use a Set node, and then a Google Drive and Google Docs node to do this. This creates some test data, duplicates a Google Doc with replaceable text, and then updates a Google Doc with the information.
You can also take a peek at our documentation for the Docs for some more information, but what I’ve given you should help you get started!
i will keep in mind mot to ping you
