I need to send a POST request equivalent to this curl command:
curl --request POST \
--url https://target-server/api/v2/get/page \
--header 'Accept: application/json, application/problem+json' \
--header 'Authorization: MyToken' \
--header 'Content-Type: application/json' \
--data '{
"filterSets": [
"filterCombineOr": false,
"filters": [
"field": "email",
"operator": "eq",
"value": null
"includeInactives": false,
"limit": 100,
"order": "createdAt",
"orderDescending": false
I am trying to achieve this with a Request node, but I need to send the --data and don’t know how to do it. Where or how should I specify it within the request node?
- n8n version: 1.73.1
- Database (default: SQLite): default
- Running n8n via (Docker, npm, n8n cloud, desktop app): cloud
- Operating system:
