Hi, I need to create a workflow that update the data from prestashop to data studio, but i don’t see any option from nodes that allows to do this.
@victormiranda can you please provide a bit of context. What is Data Studio?
Data studio is a google tool to create reports
Ahhh you meant Google Data Studio. Yes, Google Data Studio has an API but it’s quite limited.
create a workflow that update the data from prestashop to data studi0
As far as I know, Google Data Studio connects to the database directly (e.x Prestashop’s database) and keeps the reports up to date.
Hi Victor,
I have applied several flows in that sense.
I recommend to:
- Export PrestaShop data to Google sheets (I am not sure what data do you need to export).
- Create reports using Google sheets as data source.
So, every time a new sale is done at PrestaShop, you can send data to Google sheets using a webhook. That’s a simple use case.
Hope this helps.
thanks i will intent do that
Great!
Let me know if you need anything else or support for this case.
