How do I create a trigger using MongoDB
I’d like to use MongoDB as a trigger for a workflow.
I can see the MongoDB connector “Actions” like “Find” or “Delete”, but I don’t see Triggers for something like “New Document Created”, which is what I’m used to from other low code platforms like Pipedream or Make.
I feel like I’m missing something obvious.
Thanks in advance!
Hey @NMorris,
Welcome to the community :raised_hands:
We don’t currently have a MongoDB trigger node but it sounds like it would make a great feature request, At the moment the best I can think of would be to add a created / updated date to your collections and use a schedule node to start the workflow and look for anything with a date that is newer than the last run.
Thanks Jon. I agree that it would make a great addition as a feature request. Your solution is where I landed too. It’s just way less accurate to have the 5 minute delay. But functional at least.
