I’m using an imported workflow and i get the error below. how do i set this connection using my ElevenLabs API key? no matter what i do, it just fails.
Connection xi-api-key not found in your list of connections. Add your connection from the dashboard.
- n8n version: 1.88.0
- **Database (default: SQLite):**default
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- **Running n8n via (Docker, npm, n8n cloud, desktop app):**default
- **Operating system:**default
