good day everyone.
How can I get the body from previous node? I wanted to use the content of the body to rewrite it to another http node with POST method. is my json body wrong? or is there any missing syntax I overlooked?
Thank you.
cause when I manually add the news context it does rewrite, but when I use {{ json.body}} it doesn’t work and change language.
body from each different news, so i had to use json.body
@Everett_Sobinsky , to utilize body in the JSON field you have to switch to expression mode. The error about invalid JSON stems from the body’s multi-line string as JSON does not allow it.
To resolve. compose your JSON as below
"inputs": {
"input_text": $json['body'],
"translate_to": "english"
"response_mode": "blocking",
"user": "abc-123"
This will turn your multi-line string into a single line.
Moreover, I see no reason for the 2nd Split Out node. That is, the following should do
