Tried using using search but didn’t see an answer
I’ve got some older workflows kicking around that contain stuff I like to re-use as snippets in new workflows.
I’m not a coder by any means and have a 66 year old brain so those are probably the main reasons I do it this way
Anyway, I eventually noticed when trying to debug a new workflow that the (in this case) Wikipedia tool was sitting at v1 and there was a new v2 version available when adding it manually.
I presume this is the case as I copied/pasted this older node.
Is there any process that tells me about old node versions?
Or being able to upgrade/update a workflow with new node versions.
There’s nothing obvious that I can see that tells me of older node versions.
Any tips would be greatly appreciated.
- n8n version: 1.75.2
- Database (default: SQLite):
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Operating system: Linux
