I want to store some data and state during current execution somewhere and then reuse it in next executions. What is the easiest way to do it?
Using cloud n8n
Using cloud n8n
You could try something like Baserow Cloud and store your data including keys like a timestamp ($now
) and $executionId
or whatever else you would need to figure out which “previous execution” you want to look up and use in the “next” execution. Curious how you will know your executions won’t run concurrently. The notion of “current” and “next” execution are a little ambiguous normally.
Solved it by saving state in supabase table; clunky but works
