I really don’t understand how the Loop node works, I’ve read so many topics here, but I haven’t found a solution to the problem. I don’t even know how to describe it, it would be better to show it on video, but I don’t see the possibility to attach it here, so I’ll upload it to YouTube https://youtu.be/V1LISoRkas8
In short, the loop changes its behavior every time in a new way, when I want to test the loop to get data from the previous step, it returns a response only depending on the next steps, that is, for testing I have to disable all subsequent steps.
And after each test, the data is reset and I need to do all the steps again, why isn’t the data from the previous step simply used?
no errors
- n8n version: 1.80.5
- Database (default: SQLite): SQLite
- n8n EXECUTIONS_PROCESS setting (default: own, main): main
- Running n8n via (Docker, npm, n8n cloud, desktop app): Docker n8n cloud
- Operating system: Linux
