How does split in batches understand how many times it has to run?
The split in batches should run like 19 times for me but it is only running twice. I do not understand how it calculates how many times it has to run? Can someone explain please :slight_smile:
Kind regards.
Hi @timautomation
It keeps track of that inside the node. it can be found in the context of the node.
If it isnโ€™t running as often as you expect it can also be that it simply isnt getting another input making the loop stop as the node is simply not triggered.
If you need specific help with your flow please show us what is going wrong.
Thanks for your answer, I still do not understand how it keeps track. But I will close this thread and make a new one as im not using the Split in batches node anymore.
