How does the Airtable > Update work?
I have a table which includes two columns. key & value. One of the records has key = date-updated. I use the Airtable node to get this record. Out comes the following:
"id": "recordId",
"fields": {
  "key": "date-updated",
  "value": "2022-01-22 09:55"
"createdTime": "2022-01-25T08:52:39.000Z"
Now, I use a Date/Time node to get the current date and time in the same format as the fields.value. From the node, I write it directly to the same position, so the Date/Time node returns:
"id": "recordId",
"fields": {
  "value": "2022-01-25 12:26"
Directly after, I use the Airtable node again and use the Update operation. As the record ID, I use the ID from the previous request.
Now comes my question: Where do I tell the node, what data should be put into the field? I can specify the field to update, where I put Fields: value, because this is the only field that needs my manual update. But where do I tell the node, what to put in that field/cell?
When executed, the node returns the old data again (see first json response above) instead of the newly set.
I tested a lot with the update operation and I cannot for the love of me find out, how it is working.
Hi @wohfab, the Airtable node would update fields in Airtable using incoming fields matched by their name/key.
So if you wanted to update a date-updated field of with a value of 2022-01-25 12:26, you would need to create an n8n item having a structure of:
  "id": "foo",
  "date-updated": "2022-01-25 12:26"
This would typically be a job for the Set node:
Here is a quick example workflow demonstrating this (don’t run it against your production data, it just updates all rows with the current time in the date-updated field):
Example Workflow
Oh, perfect, @MutedJam! Worked :slight_smile:
Hey @MutedJam - I have exactly the same use case and struggling to find a solution despite having followed your advice.
I want to update my Airtable base once the e-mail is found:
Here is the configuration:
But I’m facing some incoherence with the ID: Here is an example :
Any idea ?
10000 thanks !
Hi @fischera, I am sorry to hear you’re having trouble but I am not sure I fully understand your question.
Your post suggests n8n might have updated the wrong dataset which looks different from the problem originally reported in this thread. Perhaps you can open a new topic and provide all details required to reproduce your problem, ideally in a simplified manner (a small Airtable with a handful of rows and a workflow that should update one of these rows but actually updates another)?
thanks @MutedJam - will do
