Hey @Jim_Le - at a high level Ask Steve is a UI that makes it easy to:
(a) Ask an AI to do something without leaving what you’re doing
(b) Enable it to see the context of the current page
(c) Create reusable macros so you define your “tool” once and then use it over and over again.
I don’t think Operator really changes any of these things, it just means that the AI can do more tasks than it could before. I’m looking forward to playing with it when it becomes more broadly available!
