How I Scraped LinkedIn Profiles With n8n In Minutes!
In this video, learn how to use n8n for n8n web scraping of LinkedIn profiles, extracting valuable data such as names and job titles. This n8n tutorial shows you how to create a workflow to gather linkedin data, providing a solid foundation for lead generation. Boost your B2B lead generation with this powerful technique!
Feel free to look into this new Node, created by SourceGeek, where you directly can extract the (enrichted) profile data into from any LinkedIn user:
i tried doing the same i m getting continous error that the key is not supported. i cross checked all my api keys and doesnt seems to be a problem.
Rather some post mentions google is not allowing new users to use custom search. is this correct ?
kindly let me know .
