I don’t know if you’re lazy like me but I never categorize my wordpress posts. Well, 82 posts into my site and I decided I need to categorize them but just thinking about all the clicking gave me a heart burn.
Before and after I run the workflow!
So I created a workflow to do it for me. It passes the blogs to chatGPT to categorize and then changes the category of the post.
- You come up with some categories first. (1 category for 10 posts on avg)
- Then run n8n automation to get A.I. to set the category for each post.
It’s that simple. It did take me 10 hours to figure out all the little details. Incase others find it useful, I’m sharing the template here. You just need to download the template, add some credentials and you can save 10+ hours of work.
Here’s the workflow
