How is pairedItem supposed to work in Code node?
To make sure expressions after this node work, return the input items that produced each output item
“name”: “Jane Doe”
n8n version: 1.122.3
Database (default: SQLite): default
n8n EXECUTIONS_PROCESS setting (default: own, main): default
Running n8n via (Docker, npm, n8n cloud, desktop app): npm
Operating system: MacOS Tahoe 26.0.1
ramin1
November 28, 2025, 3:48pm
2
basically each output item must reference an input item. this is item linking mechanism
itemMatching() usage example | n8n workflow template .
So can you explain why the error in my example workflow?
ramin1
November 28, 2025, 4:07pm
4
There is no error in the example you provided. it is odd definitely.
you send two item to code node
"name":
"John Doe"
"name":
"Jane Doe"
and in code node decides to return only the last one that would be “Jane Doe”
and paired it with the first input item.
in the example in my previous post i add a third node showing that item is linked to first item
item linking just created a chain between items in different nodes, it does not change data that you output in any way. “jane Doe” would be “Jane Doe” but underhood is linked to “john Doe” of the first node
If you want to likn Jane doe to Jane Doe of the first node pairedItem must be 1
So why do I get this warning? It’s like I’m not pairing at all:
ramin1
November 28, 2025, 4:15pm
6
I do not that sentence in my instance, but i don’t think that would be an error. it is more like a reminder
As i said, this workflow is definitely strange and i regarded it for just learning
And one more thing, most of the time it is not necessary to pair items manually because n8n do it automatically for you
system
Closed
February 26, 2026, 4:15pm
7
