Hello this is my configuration :
i m on premise :
- n8n version: : 1.64.3
- Database (default: SQLite): Postgress
- n8n EXECUTIONS_PROCESS setting (default: own, main): : default
- Operating system: : Debian 12
hello i got a node with multi Item, but how i can acces in code at this différent item
so i need to access at Covnerie-CMLToJson who is a json and show same data on it ?
Do u know how access data pleasse ?
i try with code node, can acces at différente node but with node to acess XML data ? and start do some request on it ?
THanks
ihortom
2
Hey @Issa2024 , here’s the doc with the information you are looking for, Output of other nodes | n8n Docs.
Hello after hour and hour of searching i found this solution
// Récupérer le champ texte depuis l'entrée
const text = $input.item.json.text; // Assurez-vous que 'text' est le nom correct de votre champ
// Récupérer les fichiers binaires associés à l'entrée
for (key of Object.keys(item.binary)) {
fileName = item.binary[key].fileName;
directory = item.binary[key].directory;
// Ajouter ces valeurs au résultat JSON
return {
json: {
result: [
{ fileName, directory }
And this is a demo of workflow who open a pdf files, read all data from a pdf and extract data on it
system
Closed
4
