Hey @ManyQuestions,
You would need credentials to upload so one thing you could do is use a generic credential which uses expressions then pull your clients credentials from another database to use them.
via http request?
or the Wordpress node so you can create a credential that uses an expression like this…
Then in the node before you call it you can do some database query that returns the user / pass / url for your client and it will magically pick them up to authenticate.
Uhhh- this look interesting. I’ll check it out!
It’s working. THANK U!!
