In this video, learn how to create an AI assistant agent using the n8n local for free. This step-by-step tutorial guides you through setting up the workflow automation, demonstrating each part of the process on-screen. Perfect for those looking into self-hosted options, this N8n tutorial shows you how to use the local version.
@ alirezachegini
Hi, Welcome to our community
You mentioned that there are documents related to this video. Could you please share the links in your reply?
