I’m currently exploring AI chatbot automation using n8n and wanted to get some insights from people who have already built something similar. I understand the basics of n8n workflows and how nodes connect with APIs, but I’m trying to figure out the best way to create a complete chatbot system using it.
Specifically, I want to build a workflow where a user sends a message (through a website chat, Telegram, or another platform), the message is processed by an AI model, and then the response is automatically sent back to the user. I’m also interested in adding features like conversation memory, storing chat data, and possibly integrating it with other tools like a CRM or database.
Here are a few questions I’d really appreciate help with:
What is the best way to structure an AI chatbot workflow in n8n?
Which trigger nodes work best for chatbot integrations (Webhook, Telegram, Slack, etc.)?
How do you handle conversation history or memory in n8n workflows?
Are there recommended nodes or patterns for handling AI API responses efficiently?
Has anyone implemented multi-platform chatbots (for example website + Telegram) using the same workflow?
I’ve seen many businesses building automated chat solutions, and even some teams working with a chatbot app development company to implement scalable solutions. However, I’d like to understand how much of this can be built directly with n8n workflows and what best practices the community recommends.
First make it work using something (webhook, telegram..etc) make sure the messages come in and goes out, the primary problem you would face is that if a user sends “I want to build something like this” and then shortly after they post another message like “complete AI automation chatbot” so now the problem is that each message is treated as a different call, so see how you find your way to tackle this most common problem.
I would recommend consider Webhooks first make them working and then move to telegram and slack as webhooks are quick to setup and works all the time.
Currently use a simple memory node as a memory element, get comfortable then know its limitations and then consider using Supabase Node for memory management that is the best and easiest.
Oh just make sure you are frying the API limits , for now do not spend money on API keys use Openrouter they provide free credits with AI studio if openrouter key gets exhausted. Also make sure to implement a pattern so that AI is only in use when needed and curate some basic replies using n8n without AI like “What is the time?” this kind of similar should output in {{$now}} i mean you need to use an text classifier but this would save a lot of costs in large computation requests.
Oh i have done that, it is fairly easy just make sure you are routing everything as it is needed use Set Nodes to make sure every input and output has same name so that $json.output can be carried by both telegram and Return to webhook node.
You can build a complete chatbot like fully furnished end to end even you can add front end if you go wild usng HTTP node and Forms , although just go with basic input output for now and make sure they are working before considering bigger steps.
We are here if you feel anything is holding you back.
Hey welcome! The core of what you want is the AI Agent node, its basically the brain of any chatbot workflow in n8n. You hook it up to a Chat Trigger node (which actually gives you a built-in chat widget you can embed on your website), connect an LLM sub-node like OpenAI or Gemini to it and attach a memory sub-node so it remembers the conversation. For persistent memory that survives restarts Id go with the Postgres Chat Memory node, the in-memory options lose everything when your instance restarts which is no good for production.
For multi-platform (like website + Telegram) the trick is to make a sub-workflow that contains your AI Agent logic, then have separate trigger workflows for each platform that call into that shared sub-workflow using the Execute Workflow node. That way you write the AI logic once and just pipe messages in from wherever. Here’s a super basic starter you can import and build on:
Youll need to add your OpenAI credentials to the model node and swap the Window Buffer Memory for Postgres Chat Memory once youre ready to go to production. The n8n docs on advanced AI are worth a read too: n8n Advanced AI Documentation and Guides | n8n Docs
To build a professional AI chatbot in n8n, the most effective approach is to use the AI Agent node to orchestrate tasks, combined with a Postgres Chat Memory node to ensure the bot remembers user history across sessions. For a multi-platform setup, you should create a central “brain” sub-workflow that handles the AI logic, which can then be triggered by separate platform-specific nodes like Telegram or Webhooks. This modular structure allows you to easily integrate other tools like a CRM or database, turning a simple chat interface into a powerful, automated business engine.
