Context
As you can see (in the following screenshot) i reached the timeout of and S3 call. No matter why… shit happens, I’d like to accept the fact that this issue can happen and just retry. But i want to fail faster than 300 seconds.
Question
How can i change the default timeout for the s3 node? ( i can’t find it in the settings neither in the documentation for the node)
- n8n version: 0.193.5
- Database you’re using (default: SQLite): postgresql
- Running n8n with the execution process [own(default), main]: worker mode
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: onprem k8s install
